06.28.2009, 08:43 PM
I dont think the vxl esc has a brushed motor option, so it wouldnt work regardless.
You'd need an MM esc, then it would run the big drill motor just fine- gear something like 18/72 for ~30mph top speed. You will need a new motor mount though from Kershaw Designs as the dewalt is alot fatter, and you would also need 5mm bore pinions probably.
Interesting use of a shin guard...
