06.29.2009, 01:03 AM
Originally Posted by Doug Shelp View Post
well i ran out of time and didnt get all the options tried but i maxed out the punch ,no joy. advanced the timing,no joy.and the ESCwent 160 and the motor went 140.Then after my main iincreased the start power and only had 2 laps to try it and it didnt seem better but im not sure maybe a little.still thinkn the 36-50/4800 might have been a better choice but ill try a few more settings and see.
Was this with 2s or 3s? If it was with 3s you may want to add another cap and an external bec to the MM. It takes alot of waste heat to make 5v out of 12v, so disabling the load from the internal bec and running an external one should get the job done.
Motor temps of 140 are ok, I would not worry too much on that.
