Ryu James
Ryu James's Avatar
06.29.2009, 02:06 AM
Originally Posted by chase View Post
x1 so no tekno chassis
ok, so here is what i would do. isnt the x2 just longer than the x1? but has the same screw pattern for mouting the front, rear, and center assemblies to the chassis? arent most of the parts compatible? i looked at doing a x2 conversion back when it first came out and if i recall almost all of the x1 hopups fit the x2.
so back to what i would do. i have had friends doing this with their 8ight 1.0 kits.
make sure the parts are compatible and if so buy the tekno x2 conversion kit and then buy the x2 center CVDs. this way you get the extended chassis of the new x2 but without having to buy one. alot of people are doing this same thing on 8b and 8t conversions. just buying the tekno 8ight 2.0 conversions and a rear CVD and turning their 8 1.0 into a brushless 2.0 respectively.
talk to tekno as they will know if the parts match up from the x1 and x2 and whether you will need both the front and rear center cvd or just the rear cvd. and check out amainhobbies.com to find the CVDs needed as i dont think tekno carries many jammin parts.
Jammin SCRT10 Neu 1512 1y
