06.29.2009, 02:35 AM
Ok, so far I have the following info:
MM
Medusa 36/60 3100kv
3s 3200 lipo
4.1" tall tires
Stock crt.5 diffs and spur
Unknown gearing
But with some sort of novak hv motor on 3s lipo and 13/46 gearing it was geared appropriately for the track.
Can you fill me in on the kv of the novak motor, or at least the wind count?
a 13t pinion on 3s looks pretty good to me for what you are doing:
Differential Ratio: 3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 13
Total Voltage: 11.1
Motor KV: 3100
Tire Diameter (inches): 4.1
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.004
Spur/Pinion Ratio: 3.54 : 1
Total Ratio: 11.5 : 1
Tire Circumference (inches): 12.88 inches (327.17 mm)
Total Motor Speed: 34410 RPM
Vehicle Speed: 36.5 mph (58.63 km/h)
Effective KV Value: 3100
I would definitely install an external bec, that will help with the esc temps on 3s.
