Originally Posted by nitrostarter
Ok, I understand your A123 voltage, but are you running (2) 2s2p packs in series for a 4s2p combination? Or are you running 2s2p's in series to make 4s1p?
Also, if those lipo's are anywhere near the Zippy's in quality, you'll notice a huge difference over the A123's. Also be aware that the 4s lipo voltage is 14.8V where your A123's are 13.2. Besure to adjust you gearing accordingly.
i run 13.2 volts at 4600mah, is that 4s2p or 4s1p???
these lipos i have them for almost 2 months and only now in this car i will test them seriously...
i am thinking gearing this 2350kv hobbywing motor at 14 or 15 pinion to 48 stock spur...
i have also purchase 2 losi plastic spur gears one 43t and the other 45t.
and i have already take a look at the losi center smart diff but first i will test the car stock...
should i put lighter or heavier lube in the diff´s for working with brushless??
i know that it comes with 5 front, 7 center and 1 back....
regards
