06.30.2009, 01:25 PM
...BrianG, I am wondering if I should make another larger cap bank on the Quark in a reciever box (asthetics) with the 'no-spark mod? It can't hurt right, lower the system resistance further, can only be good for everything I would think.
Electrically, I'm sure any bit helps. But realistically, you run into placement/mounting issues. Also, if the caps are soldered somehow to the ESC, the weight of bus bars and the caps themselves would place considerable stress on the PCB. And, at some point, you get very little return for the work/expense. If you already have twenty 500uF caps (10,000uF), adding 4 more to get 12,000uF isn't helping a whole heck of a lot.
Originally Posted by crazyjr View Post
...BrianG, I forgot i also switched to a quark esc as well. Is it possible that the quark has the same gate like thing as the castle monster?
I'm not sure, but I don't remember seeing a TVS device on the Quark. Of course, I never looked specifically. The ones I've seen are roughly the size and shape of a typical FET that you'd find on an ESC (square/rectangular and flat), and it has two leads.
crazyjr, I believe the eagletree doesn't read/record negative currents, I think it must have been either a glitch or just a current peak.
It might not record currents below zero (has anyone even tried setting the graph low point to a negative number?), but there should be a voltage peak that may be at or above the battery voltage.
