Thread: Scorpion packs
MetalMan
MetalMan's Avatar
01.06.2006, 11:08 AM
Expensive... You really don't need that much of a power supply. This is the one I use:
http://www.emtel.com/search/product_...t_id=EMV15012V
It's cheap, pretty small, and works well. Unless you will be charging at 10amps all the time, it should work well for you. Besides, charging a 3200mah pack at 10amps would be over 3C, which would reduce the battery's life.
