Shark413
Shark413's Avatar
07.02.2009, 03:57 PM
Update:
It was really hot out here in Socal at the end of June, but the track is going to be closed for a few weeks so I wanted to get one last weekend of practice to stress test the Tekin motor (and new rotor). It may not get as hot as some places but the the air temp was 106 degrees and the track surface was 135 degrees, so this was a good test on how the battery, ESC and motor would handle the heat. I put three 4s Neuenergy packs thru, I dropped down a tooth on the pinion because of the heat (47/14T). Max temps on the motor were in the low 180's and the Battery hit 110. Performance was great the weather was not.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
