07.03.2009, 09:19 AM
OMG that a hvy truck! The 1527 is huge! that should do the trick.
You may want to get an Eagletree at some point with all you've invested so you can look at power levels amp draw and even temp sensors. Really nice to have to dial the setup in (ie gearing etc) so you don't run the risk of damaging any components.
BTW, did you make a FS post? You should link in your sig.
