07.03.2009, 10:06 AM
If you run 10-12s and are not trying to gear too high I am sure the hv180 will work. Up at 10 and 12s pulling more than 100amps is making some serious power. I used a 60amp esc on 8s in a savage and had no issues, so triple that rating with higher voltage in a 15th scale should not pose a problem.
RJ, can you weight the chassis without the motor or batteries as it sits with the tires on? Just wondering what it will weigh with my proposed setup, and I know the weights of all of the individual components.
