zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.03.2009, 03:46 PM
~7.1volts off the charger, but for this application, I could just use a lower charging voltage (3.5v) so it's 7.0 volts, then I fairly rapidly drops to 3.3volts/cell or 6.6volts for almost the entire discharge.
Also should be zero electrical noise using a pack, might help with radio reception at distance?
Weights 150 grams, BTW.
Do you guys think the 7940TH is a good racing servo? Running off this pack, it should twist around 200 torque, and 0.065 sec transit. For a Revo.
