07.03.2009, 06:06 PM
It won't "blow" the ESC, after all, setting a lower value is simply like driving with the trigger not open all the way. However, ESCs do run less efficiently at less than WOT.
If you want to slow it down, gear down, use lower voltage, or use a lower kv motor.
