07.03.2009, 09:02 PM
I doubt it, the sensored motors use a hall-effect sensor to generate a signal- the sensor has to be plugged into a sensored esc for it to interpret that signal & 'see' the rotor posistion. Unless the logger is capable/ compatible with hall sensors it probably wont work.
The Eagletree loggers do get rpm data somehow though- voodoo magic I believe.... :/
