crjackson
03.10.2005, 11:49 AM
Originally posted by RC-Monster Mike
That more or less seems to eliminate the UBEC as the culprit (I am glad for this, but still somewhat befuddled as to what is causing the problem). It would appear as though the radio is causing some problems now. What are you using for the main batteries? Are the batteries in your transmitter charged? Do you have another JR receiver to try?
They are JR NiCd Radio tx Pack made for the tx unit.
It's the main bat packs. I'm 99% sure. I put in some freshly charged but older 6-cell stick packs. No stuttering at all in 1st gear. No power either though. It's les power that stock Titans, but I'm hoping thats due to the packs.
In shiftig to 2nd it will cut off under load. 2nd gear isn't usable really. 1st ran very good just no power.
I think what is happening is that the bats aren't able to handle the current draw under heavy load and the esc shuts it down due to poor voltage or something. That's my best guess anyway...
I'm going to order some new (again) 7-cell packs and see what happens. I wish I knew someone around here I could just barrow for testing to be sure.
If you think of anything else let me know. If new batts don't fix the issue, then it's the rx I guess...
