07.04.2009, 12:36 PM
Originally Posted by dethklok151 View Post
if you still wanted a center diff,what about making a mount for the baja diff,then using an idler gear of some sort to get the pinion to it.it might also offer some more gear reduction if needed.just a thought...
Just go one step further, and use the entire 5b tranny, make a motor mount, and attach the 1st gear in the the tranny to the motor shaft. Kinda like sikeston's direct drive emaxx tranny setup.
