Jarvis
07.04.2009, 07:57 PM
Joe, this would also be the case if you had a 6S on the 2200kv in a buggy with 30-40% epa?
Is it better to make these type of power limiting adjustments in the MMM or through the radio?
This is a good post because a LOT of people have the castle system around here with the epa set low to limit throttle. I think it is just being lazy when you can gear down or swap motors for the track.
