gimpygolden
gimpygolden's Avatar
07.05.2009, 12:24 PM
Honestly, I highly doubt this is the case. Most guys there run boats that are setup to spec. N, P, Q classes, etc... They are listed as to which battery setups are used.
Have a look at this chart:
http://www.castlecreations.com/suppo..._boat_apps.pdf
Great chart as a guideline for lower voltage setup's but not much help as I'm looking at going HV.
I guess all I really want to know is, is there any draw backs to going HV.
I realize lower volt setups are tried and true and probably even a few buck$ less, but in an effort to put less stress on these cells wouldn't a High Voltage setup be the way to go?
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
