07.05.2009, 11:54 PM
I would appreciate it if you could just do a little write up on what solder and flux to use on what and where to get the stuff from. I know the aluminum tabs need special flux but don't know what kind.
At the very least I hope you can still answer questions for us on lipo repair. Such as if all I'm doing is replacing a balance tap can I just heat up the solder thats there and get the new wire to stick? otherwise I'm prolly just gonna solder a new tap on outside the pack.
