07.06.2009, 12:13 PM
Got a little more done...
Here's the engine:
Motor mount almost done- needs to be welded on to the stiffener plate/chassis:
And the rear sprocket mounted to the wheel, this turned out really badly because I had to do this weld quickly as to not warp the sprocket past the point of no return and the fact that the wheel and sprocket are lousy steel, AND I also couldn't remove the freewheel, not press fitted or threaded... so I had to weld it to itself so the motor can help slow the bike down at idol:
