zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.07.2009, 12:50 AM
I am running 6s on the Quark (the Quark has issues with 6s), and I use only 45% brakes MAX, the EPA is set to 45%, and I usually use only 1/2 of the full 45%.
The way I brake, is usually a small amount when at speed, then I gradually depress the brakes more when it slows down, to keep the same braking action. I have never really used hard brakes ever, it's just too hard on things, drivetrain, motor (heat), and esc obviously....
