aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.07.2009, 12:24 PM
LOL, 16S would be nice if I had the controller for it.. heck, I'd run 20S if I could...
I rigged it up so if I do brake anything it will be easy to replace with stock Duratrax parts. And it's geared for 57MPH on 12S and 38 on 8S.... most/all of the parts are from the original Duratrax part... The motor mount was so easy to make.. I'll take a snap of that maybe tomorrow for you guys.. Pinion, I used the 14T 10mm bore transfer gear from the firehammer.. and for the 6mm ==> 10mm sleeve I used the support inserts which supports the petrol engine.. Worked out perfect!! I'd just have to bore it out to 8mm when/if I put the 2280 in...
Yeah, I have the front wheel disc brakes, I haven't mounted it on yet, only the discs.. I'm using the rear disc brakes on the shaft.. but I will eventually go to all around disc brakes to save my transfer gears and Differential...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
