maxair45
maxair45's Avatar
07.07.2009, 02:26 PM
Problem number one....Is it the tire itself or the tire and rim? If the tire it could be mounted wrong of so just get some CA releasant and try it again if the wheel and tire...make sure everything is tightened down and are you using the correct screws?(tie rod might be wobbeling in the thing that goes inside the rod end I forget the name right now) Some people get into the habbit of just grabbing a screw and going when it might now work properly there.
