Finnster
KillaHurtz
Finnster's Avatar
07.07.2009, 10:28 PM
Yeah, I would go with a 36-50-3300 or a 36-60-3100, both on 3s. The 60mm version will stay cooler and tolerate less than ideal gearing a little better. But either one will be fine.
x2. I use a 50mm on my .5. Works well. The Pede is quite a bit heavier, but 2wd, so can't put the power down the same way. The 60mm is quite capable of throwing around a buggy or erevo, so would do well in your truck.
3300 on 3s is nice. (I do 2200 on 4S)
