Patrick
Patrick's Avatar
07.08.2009, 06:36 AM
Originally Posted by Mentat View Post
I know i have asked something like this earlier at some point, but i am still curious, I have the following batteries and when they get re-charged they get almost 6000mAh capacity put back in. How is this so?
If your doing a balance charge the balancing process will use a bit of the mah put back into the back. The longer the cells are balancing the bigger the difference will be between what has actually gone back into the pack and what the charger has put out. Might not be the full 1000mah's difference, but could be some of it.
