Ryu James
Ryu James's Avatar
07.08.2009, 04:17 PM
so i got this new 4mm blue carbon today. it is 4mm 1k fineweave which is super tough and an outer layer of blue texalium on each side. texalium is an aluminum cloth and the stuff used for fishing rods and other sports equip.
i got this stuff cuz it became apparent that i had to move the front chassis brace to the right side of the drive shaft so the motor mount could sit where it needs to. since i had to move the chassis brace i decided to make a new front top plate. and i most likely will have to make a new center top plate if i go with the mech. brakes off the center diff outdrives. so this blue carbon should be tuff enough and looks cool too.
bluecarbon
bluecarbon3
you can see in this pic where i had to take off the chassis brace. so the new top plate will just mount the brace to the other side.
redcat20
Jammin SCRT10 Neu 1512 1y
