07.08.2009, 11:56 PM
I think I'm going to get the 5200kv eZRun. I think I had such bad luck with the 7800kv because even though I was only using a 2S that was 57720RPM which proved to be too much for the eZRun motor. The 5200kv on 2S with the MT tires should be just as fast as my old setup and run much cooler and be much more efficient.
"You can kill the revolutionary, but you can't kill the revolution." - Fred Hampton
"The common people suffer when the powerful disagree." - Phaedrus
