07.09.2009, 12:59 AM
Vendetta diffs - ~15/40 = 2.7:1
RC18T diffs - ~14/35 = 2.5:1
They're about the same. You could just gear up to compensate the very small difference. There's nothing wrong with gearing up... Final drive is all that matters.
28mm motors produce more power then 20mm motors. 28mm motors are faster then 20mm motors in any vehicle.
Any 28mm motor will own up on all the 20mm motors.
If you're really worried, you could run 3s lipo, but you'd have to get a better speed control. The 1/10th scale sidewinder is a great choice...
