Nixpus
07.09.2009, 04:15 AM
I have a question for the pro's
In general the wireing should be as short as possible, the solder job as good as possible & the connectors should be of good quality... that much I know.
But... if I should choose between long wires from battery to ESC or from ESC to motor - which would be best? Id guess option 2 is better since the voltage drop is then on the "non battry side" of the ESC?
