Ryu James
Ryu James's Avatar
07.10.2009, 11:56 AM
Originally Posted by KaztheMinotaur View Post
I like the front CF brace you made.
You can wire brush that copper color off of the rar hub carriers if you don't like it. I did that to come of my copper stuff.
The stock shock shafts are very thin and bend easily. I am running the Baja front VVC heavy safts. They are a little long but you can take that extra lenght up with some tubing under the piston.
that was the main reason i bought that parts lot on ebay. it has a set of shocks with the 6mm phatdad shafts already on them. i will just end up using those. i did also already buy a set of front VVC shocks though that i was gonna use but then found that i couldnt really mount them up. if you switch the shaft do you need to switch the parts at the bottom of the shock case that provide the seal around the shaft?
Jammin SCRT10 Neu 1512 1y
