sikeston34m
sikeston34m's Avatar
07.13.2009, 12:15 AM
Originally Posted by fastbaja5b View Post
Not sure what you're wanting, I charged the 5000mah pack at 1C on my balance charger, then hooked it up to the logger and another identical pack (no logger) on the otherside of the Savage Flux
Powered it up took it for a bash
Downloaded graph as above.
Was hoping some of you lipo gurus would have answers!
I am thinking maybe we need to set the LVC at 3.5v a cell to avoid these below 6v drops near the end of the cycle but before a 3.2v / cell cut off kicks in. Because as I said before, LVC did not kick in.
If I were you, I would double check everything. Make sure you have the latest firmware version uploaded to your ESC. I remember issues with the lvc on previous versions.
Looking at your graph, the run really started at about the 3 minute mark. The pack wasn't doing too bad until about the 15 minute mark. (12 minutes into the run).
It was at this point, it really began struggling to keep up with the load. Only 3400mah spent at this point.
Based soley on this graph, IMO, this isn't a 30C pack and it probably isn't a full 5000mah pack either.
What is this pack's size? Dimensions? What does it weigh?
