Originally Posted by Snipin_Willy
The biggest concern I have with bullet connectors as battery connection is that even if you heat shrink them they will never be as safe from shorting as deans/trx plugs. Only way to solve this is to find some type of plastic casing that the bullet plugs fit into, similar to the HC Turnigy packs
That's what EC3 and EC5 connectors are...
