Kcaz25
Kcaz25's Avatar
07.13.2009, 06:52 PM
Sounds like a familiar issue- the bearing hole in the half-case isnt deep enough for the input shaft, so the bearing crushes against the gear when its all screwed together.
Fixable if you have a vertical mill and endmill bit, otherwise it needs specialist attention or returning to FLM for rectifying.
Rather annoying really as my stock plastic halfcase is rather ropey, but I wont replace it with an FLM item if its going to give me headaches, and I aint spending $100 on a full metal tranny from somewhere else just to get the half that I want.
Right. I think. Couldn't I use a dremel?
