fastbaja5b
fastbaja5b's Avatar
07.13.2009, 09:57 PM
From what I read in the MGM article, even 5s may push the volts a bit too high under breaking, they used the example of a 6s set up on an 8s ESC, maybe we need such a high window such as run at 2/3 of rated capacity. IE run a MM at 2s not 3s and a MMM at 4s not 6s. They will run at 6s, sure, but the risk of failure especially under brakes would obviously be higher.
Say Less, Do More.
