Chris911
01.08.2006, 09:45 PM
If i set the camber right the steering don't work right. For example when i turn right and go straight again the wheels wont come back stright because that hex screw that adjust the camber is to tight and if i have it loose the steering is fine but then the truck wont track right and the wheels will wobble. I have luped all the steering parts and it seems to make no differance.
And for toe in both tire rods are the same length, i don't know any other way to check it.
