Thread: battery
07.13.2009, 10:28 PM
If you are really concerned about temps...look at the hypersion, FP or the ones Mike sells here in the store. Zippies are a great bang for the buck, but they are not quite the same quality as the top tier of batteries. However, if you are only bashing, they would do just fine. You may want to look at a 30c rated zippies as a higher c rating will hold up a bit better under load
