jordan...
one.five.two.seven
07.14.2009, 10:12 AM
thats right, the 28025, i'm a bit puzzled over the heat as well, the MGM shld be able to handle the amps way better, are there any settings i could change in the controller that would effect the heat issues, motor timing or frequency or something?
Havent really been able to run with a body because of the heat, but id use the jconcepts truggy body with the MGM or the F-150 body with the MMM as ive trimmed it to fit.
Goiod to hear from you Jerry, got all your maxx builds up and running? Not sure about projects, ive got a summer (winter for you guys) project in mind which involves a custom chassis with revo or truggy front/rear ends, 10s and a 2230. But im not sure if that will ever happen.
I think ill gear down, but im leaving again pretty soon, so that might have to be in december
