mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
07.14.2009, 12:09 PM
No Pocoyo! No Velcro!
I did one side this morning. I used parts of what I think is a TMaxx rear body post. Don't know why I had that. The high lighted parts are what I used. I secured it to the top of the batt compartment with an M4 flat head screw, countersunk in the plastic so that the inside of the compartment stays flat and smooth. I will try thick Lexan for starters to see if it holds up, I cut it in the shape I wanted and secured it to the batt door with 4 M3 flathead screws and nuts. Those screws are counter sunk also inside the batt door. I have a feeling this is going to work very well.
No brain, no headaches.
