Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
07.14.2009, 07:09 PM
you wouldn't really use a cnc to do clean up work like this. a mill, yes. CNC is computer numerically controlled- you wouldn't write a program for a CNC for one cut on a mill. There are CNC plasma cutters, water jets, mills and other things, CNC is just how they're controlled.
I imagine with my good carbide bit on my dremel I could add 1mm to a bearing hole. It would be easy to screw it up, but I'd try it.
As long as you use an end-mill bit, because a drill bit won't work...and you better have a hand that is as steady as a robot, because you are making the hole deeper, not larger, and if you aren't robot steady you will mess up the diameter of the hole.
-Chad
PM ME IF YOU HAVE THE BELOW:
