07.15.2009, 03:11 PM
Originally Posted by KaztheMinotaur View Post
That gear is big. Seems like the whole thing could be thinned out,maybe 1/8, and then a smaller section out of the middle "counter sunk" where it botls to the locker.
Is that gear hardened?
The sdp gear will not be hardened. May be the only issue with it, depending on what pinion gear you plan to run. I would leave it full thickness, or only mill it down to match the teeth width on the rcm mod 1.5 pinions.
