Not sure what firmware version I'm running. I can't
quite read the computer screen, which is about 4 miles away in my basement and on Standby.
If I think of it, I'll check when I get home, but not sure how much use it will be since I have a V3. The program may display differently for different versions. I know my "what to log" screen has a TON more options on there.
Have you tried uninstalling the software and then re-installing? Shouldn't matter, but these are Windows based computers after all...
FWIW: the V3 has more memory, enough to log V, A, and 1 temp probe for over 40 minutes at the fastest 100ms sampling rate. So, if you have to get a new recorder, at least you can justify it a little easier.
