07.15.2009, 07:20 PM
Ever seen those spinning signs they have outside some shops powered by the wind, they have one word on the back (top) and another on the front (bottom); when the sign spins you see both words together.. (like 'fish & chips') etc. Stick a shaft down the middle and mate that to your motor via the belt drive or whatever you plan to use...
http://www.youtube.com/watch?v=V-PiJrD4P4M
They are shaped basically the same as the turbine you want to use, only in a single molded piece.
