zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.15.2009, 09:22 PM
Aight, after a long wait from Eagletree about my non-working eLogger, I just went ahead and did a discharge test in LIVE mode with my laptop. So here we go...
Testing I used my electric 24V lawnmower on idle (just sitting there), as I figured it would be a pretty good constant load for the packs. Also, the loads are not that high, only 6C, but still, the purpose of this was to compare the discharge 'CURVES', the flatter, the better.
On test:
-6s Hyperion VX 25C 4350mah - Enerland based pack
-6s Hyperion VX 35C G3 4200mah - Unknown 'new gen.' based pack
Now you should note that I am pretty positive the current readings are off, as both of these packs only discharged 3823mah(4350mah rated), and 3950mah(4200mah) respectively.
The 25C pack looks to get 21.5volts average discharge.
The 35C pack looks to get 22.0volts average discharge.
Keep in mind that my eLogger is not accurate, and that actual voltages and currents will be different, probably higher. (me know it is) But for comparisons purpose, it is a good relative test.
I inserted a thin red line at 22volts for reference purposes.
HERE is the 25C Enerland based pack
HERE is the 35C G3 based pack
I hope to do some more higher discharge test to show more accurately what each pack is capable of.
Cheers
