07.15.2009, 09:46 PM
Originally Posted by Chadworkz View Post
As long as you use an end-mill bit, because a drill bit won't work...and you better have a hand that is as steady as a robot, because you are making the hole deeper, not larger, and if you aren't robot steady you will mess up the diameter of the hole.
it'd be no different or harder than drilling any peice in a drill press. set the peice, set the depth stop, pull the lever. no computers or "robots" necessary.
