stum
07.16.2009, 09:41 AM
May want to replace the diff case... mine got a little loose on the front and I ended up chewing up a front diff gear $$. Also just make sure the bearings are sound.. typically when slop develops you find your bearings are shot or on the way out, at least that is what I've seen more times than not.
