07.16.2009, 05:13 PM
A motor is generally ok as long as the metal doesn't rust. Is this a "real" Neu, or a CC/Nue? Blowing out the water on a real Neu with the holes in the can will be easier obviously.
Personally, I'd blow it out thoroughly with the compressor, then spray in a little WD-40 especially on both sides where the bearings are, work the motor a bit (to get the WD-40 all around the bearings), and then use the compressor again.
