GO-RIDE.com
07.16.2009, 09:31 PM
Originally Posted by medusa'd maxx View Post
Sorry about the skimming - got to stop posting at 3 am
in response to above
Its an 8T 1.0 with a tekno conversion, Medusa 36 80 2000kv on 5s geared 13 X 48
I have the Alu Inserts
I have two shims (all I could fit) on the ring gear side of the diff
no shims on the pinion
It skips only when I mash the throttle
I'm wondering if the motors flexing the diff case
Or should I try shimming the pinion
That's a lot of motor for just about any RC vehicle. Maybe you need to add some punch control or you will probably keep over-powering the gear mesh.
E-8ight - Tekin RX8 2000kv/4S
