jsr
07.17.2009, 12:52 AM
The short straights may help in my favor as the nitros might not be hitting full tilt during that time. The only one that's pulled on me thus far is an 8ight 2.0.
When I'm on/off throttle, I'm not hitting full throttle. A lot of it is partial throttle which won't draw the same surge currents as a full throttle pull. The only times I can hit full throttle is entering the straights and two jumps, of which if I don't exit the previous corner right, I can't hit full throttle either. Faster throttle changes will result in higher surge currents and more ringing (residual current bounce). Slower throttle changes don't cause as much overshoot.
