rootar
rootar's Avatar
07.17.2009, 06:24 PM
my dx3s goes nuts if you leave it on the voltage drops down, i has the same battery compartment as the dx3r so im thinking why cant we get a 2s lipo thatll fit in there and run the ccbec set on 5.5 volts and then even close to the lvc its would still be supplying .5 volts more than the bec is putting out..... you can get a novak blinking LVC and mount it ontop of the base and just wire your on of swtich BEFORE the lvc and bec
so youd have the lipo, plug, switch, lvc in parrell, and then the ccbec before it goes to the radio power leads .....
did i confuse anyone else or just me?
honestly i use the energizer lithium AAs and they last for 6 months getting used every weekend alot...
