rootar
rootar's Avatar
07.18.2009, 01:18 PM
alot of us run that motor in buggies and revos and the temps are always amazingly low, id change your start power to high, and punch control on 30-50 %, also if you dont have holes it your body its time to open it up... also gearing up 1-2 teeth would help your motor temp. its sounds like its running at too high an rpm too much....
gear it up and raise the start power to high (low is for 2wds, med is for really light cars, and high is for all the 1/8ths and MTs because they need a good bit more power to intially move, so raising the start power makes it less lilely to cog and makes it easier on the esc....
