07.18.2009, 02:55 PM
You might be better off measuring your differential from bearing to bearing and you might be able to use a center diff from a vehicle that does accept plastic spurs. I have an RC8T that I recently converted over to an associated plastic spur, def a lot quieter! If the associated center diffs will fit they can be picked up for about for about $25 on ebay
